Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
what is this?
tazzer
08-11-2014 19:26:10
This on a ford 2120 4x4 with loader that I got with the place I bought. It had sit for a year before I bought the place and had lost the plug but had a rag of sll things shoved in it. Anyways it has a bad leak also and the pic is wjhere the leak is its on the right side below the break [img][URL=http://s715.photobucket.com/user/tazzer5030/media/IMG_20140811_121511756_zps6hosvg67.jpg.html][/URL][/img]
tazzer
08-13-2014 12:45:32
 Re: what is this? in reply to tazzer, 08-11-2014 19:26:10
Thanks Sean. That gives me a start.
tazzer
08-13-2014 12:56:33
 Re: what is this? in reply to tazzer, 08-13-2014 12:45:32
Just talked to a guy i know and hes going to split it and replace what needs replacing for 350 and i buy the parts.
Sean in PA
08-13-2014 11:32:40
Sorry, I had replied last evening but for some reason my reply didn't post. Here is a link to the parts diagrams for the various clutch housing and clutch assemblies for that tractor. There were a few different ones:
2120 Clutch Housing & Clutch w/12x4 North America 1987-2/89
2120 Clutch Housing & Clutch w/12x4 North America 3/89 and up. After S/N UV32235
2120 Clutch Housing & Clutch w/12x4 Europe
2120 Clutch Housing & Clutch w/HSS
All of them appear to have the same part number for the clutch shaft bushing, SBA398510010 (labeled as number 2 in each of the diagrams), which is what you would need to replace if it is leaking around the clutch shaft, in which case you will need to split the tractor to replace them.
But from your pictures, it looks like it might be leaking around part 6, which is part number SBA398110760 in all of the diagrams, and is simply called a rubber cover, which looks like it is just pressed into the hole, in which case you should just be able to replace them.
It also looks to me like the clutch housing is supposed to be dry inside, but I may be wrong. But if it is supposed to be dry in there, you've got a leak into the clutch housing from either the rear of the engine or the front of the transmission, in which case you'll need to split the tractor to address that leak.
tazzer
08-13-2014 08:20:01
 Re: what is this? in reply to Missoura, 08-11-2014 19:26:10
Any help folks , Im I going to have to break the tractor in half?
tazzer
08-12-2014 12:21:35
 Re: what is this? in reply to Jerry/MT, 08-11-2014 19:26:10
Ill try to get a better pic but its in a hard place to take. The last pic is where it's at, thats the breaks u see to the left.
tazzer
08-12-2014 14:55:40
 Re: what is this? in reply to tazzer, 08-12-2014 12:21:35
[URL=http://s715.photobucket.com/user/tazzer5030/media/20140812_163013_zpssvojigtn.jpg.html][/URL]quote="tazzer"](quoted from post at 20:21:35 08/12/14)
Ill try to get a better pic but its in a hard place to take. The last pic is where it's at, thats the breaks u see to the left.[/quote]
Ok I think I figured out what it is . I got someone to push in the clutch and it moved too I thank itw the linkage rod. I also found it was leaking a little on the side of the clutch too any ideal whats involved in changing it out? I think it has rubber grumments or something that seals it.
This post was edited by tazzer at 14:57:01 08/12/14.
soundguy
08-12-2014 07:04:12
maybee a farther back pic that shows more than a foot of the tractor?
tazzer
08-12-2014 12:15:42
 Re: what is this? in reply to soundguy, 08-12-2014 07:04:12
[URL=http://s715.photobucket.com/user/tazzer5030/media/IMG_20140811_180540271_zpsjhirrngg.jpg.html][/URL]
[URL=http://s715.photobucket.com/user/tazzer5030/media/IMG_20140811_180650522_zpsz1bgufav.jpg.html][/URL]
Hope this helps.
tazzer
08-11-2014 19:28:50
 Re: what is this? in reply to soundguy, 08-11-2014 19:26:10
Iv drained all the bad oil out and put New filter to get the water out will run it for 4-8 hours and repeat until all water is gone. But need to know what to do about the leak
