Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4000 Parts Online
Ford 4000 - Where is the darn engine oil filler?
FordPig
08-09-2014 20:18:04
Alright, I feel pretty stupid.
1963 Ford 4000 4 Cylinder gas.
Where do I put the oil in this thing for the crankcase?
I only see two possible entry points:
1 on the side of the valve cover, there's a breathe there with a wingnut. Seems pretty awkward to try and get it in there.
On the passenger side of the engine, up front, there's a breather cap with a wingnut on it. I pulled it off and it has a baffle inside there with only about an 1/8" opening. Going to be REALLY slow pouring oil in that.
Am I missing anything? Where do I put this stuff?
Bern
08-10-2014 14:54:11
 Re: Ford 4000 - Where is the darn engine oil filler? in reply to FordPig, 08-09-2014 20:18:04
Just ask any young blonde to point out the "710 cap" for you.
Texasmark1
08-10-2014 12:57:37
While you are adding oil as others have indicated, when finished, go up to the other wing nut on the valve cover cap "hootus" and take it off and clean the screen. Berryman's Chem tool aerosol is perfect for the job.
Mark
Tom Bond
08-09-2014 20:31:47
 Re: Ford 4000 - Where is the darn engine oil filler? in reply to dobaroy, 08-09-2014 20:18:04
Fordpig, it's the one up front with the wing nut on it. It looks like an 1/8" slot but it's really bigger than that. It will take oil pretty quickly as I've changed mine several times and never had any problem with an overflow from the filler tube. Might be a good idea to get yourself an owner/operators manual to show you all the fill/drain points for fluids on your tractor. You can find one in PDF format on a few other sites if you Google "FORD 4000 MANUAL".
FordPig
08-09-2014 21:01:59
 Re: Ford 4000 - Where is the darn engine oil filler? in reply to Tom Bond, 08-09-2014 20:31:47
Thanks guys, I thought that was it but wasn't certain. I guess I'll try pulling harder on the cap rather than taking the wing nut off.
I actually bought an owners manual, but all it says is "fill with oil" not where to put it.
soundguy
08-09-2014 22:05:15
 Re: Ford 4000 - Where is the darn engine oil filler? in reply to FordPig, 08-09-2014 21:01:59
Yep, it will drink an upturned quart thru the tube easilly
Ron muhlenkamp
08-09-2014 20:31:05
The breather cap with the wing nut? The whole cap pulls up and out of the 1-1/2 ? In. tube to add oil. The wing nut merely allows you to clean the filter
Copyright © 1997-2015 Yesterday's Tractor Co.
