Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 800 Parts Online
Re: ford 800 won't start
Larry NCKS
08-09-2014 17:02:13
While cranking, spray an alcohol based parts cleaner around the manifold, especially at the suspect area. If it picks up and runs, you've found your problem. If it doesn't, suspect carb or fuel flow issues.
From what you describe, it does sound like some serious planing might need to be done on the intake and exhaust ports on the head, though!
mark with ford problem
08-10-2014 00:07:13
 Re: ford 800 won't start in reply to Larry NCKS, 08-09-2014 17:02:13
we sprayed starter fluid all around the manifold with no hits or fires. my dad is 84 and a farmer. we have worked on tons of tractors, farm equip...etc when he gets the double gaskets put on I will post if that fixes it. I have had the carb apart several times and think all is clear and floats are right. each time there is gas in the bowl and unhooking the fuel line sends out a steady flow. we even put air pressure into tank while trying to start...still can't get it to pickup the fuel?
