Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
NF Numbers
Tom Bond
08-09-2014 16:37:53
Cleaning up the NF that I'm thinking of putting on the 4000. Looks like it's the correct one my tractor. Can these #'s be matched up anywhere to help me make sure before I pull the WF off? Can I use the same hubs off the WF? Some pitting on the one side but don't think it's severe enough to really harm anything just plowing snow and doing a few food plots.
Dean
08-09-2014 18:55:26
 Re: NF Numbers in reply to Tom Bond, 08-09-2014 16:37:53
Non issue.
The bearings do not turn on the spindles unless something is wrong.
Dean
Shaun Wallace
08-09-2014 18:55:05
The other side of support goes to front. Has kinda knive edge on it.
Texas!
08-09-2014 18:40:29
Ford started using those 3XXXXX numbers with the introduction of the X01 series tractors in late 1957. I'm 99.9% sure the hubs are the same.
soundguy
08-09-2014 18:54:17
 Re: NF Numbers in reply to Texas!, 08-09-2014 18:40:29
i'm pretty sure you are correct on the hubs.. my 950 frankenstein NF has 1 front hub off a newer series machine with a grease zerk and raised nubs to guard it, and it fits fine on the old 55 spindle, same bearings and all. have no idea what the hub is off of.. but it is ford...
sotxbill
08-09-2014 18:39:04
pitting could cause severe bearing failure at high speeds. So be sure to keep it under 50mph..
Sorry.. it will work fine for farm use.
soundguy
08-09-2014 17:31:26
i'd prolly run it too. if i found myself loosing sleep, a lil braze and filing and then emory paper till smooth..
Bern
08-09-2014 17:09:27
The pitting wouldn't bother me either. Of course, with a little JB weld....(just kidding).
rickb
08-10-2014 04:32:54
 Re: NF Numbers in reply to Bern, 08-09-2014 17:09:27
ROFLMAO!!!
Ultradog MN
08-09-2014 16:49:26
Good photos.
I would say run it and don't give it another thought.
