Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
spindle bearing
08-09-2014 16:18:41
hello all,
set out to replace spindle bushings on the 841 today. Got the old bushings out ok, but can"t get the remains of the thrust bearing out of the axle assembly. Tried heat, drilling, pounding from the side, all the cuss words I know, but it acts like it"s welded in. Any ideas?
08-09-2014 17:15:09
 Re: spindle bearing in reply to JonB, 08-09-2014 16:18:41
How much heat did you use? Did you use a little butane thing, or an acetylene torch? You need to get it red hot, and then you can pretty much melt it away if you're careful. If all else fails, cut it out with a cutting torch. A small gouge in the casting won't hurt much if you have a small oops. Of course, there's always JB weld... (never mind, I didn't say that).
08-09-2014 17:50:08
 Re: spindle bearing in reply to Bern, 08-09-2014 17:15:09
Yeah, I used a little propane thing. It's all I've got.
Probably need to take it to someone who knows how to use a torch. I'd melt it down, likely.
