Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 971 Parts Online
Re: 1971 Ford 2000 3 cyl gas
Des
08-09-2014 12:19:05
It appears as it is a fuel problem. All the tractors I have worked on to date were older Fords, Farmalls. As such they did not have a fuel pump, just gravity drain. In tracing out the fuel lines it appears to have a fuel pump on the top front of the engine behind the generator. I did the same as I did before and the tractor ran about the same distance and again quit. I sprayed ether again and after cranking longer than before it did fire up then stop again. Earlier I didn't take into account the long air flow from intake to engine when I applied ether. I am going to remove the pump and check it out and the lines
This post was edited by Des at 12:48:10 08/09/14.
Copyright © 1997-2015 Yesterday's Tractor Co.
