I've just purchased a 1953 Jubilee. The Proofmeter with the tractor was not working no needle and no cable. I ordered both then looked at what the connections were. The Hydraulic pump is the piston type and the the cable was cut just after the nut. I removed the net and a shaft with a spring attached was spinning. Good News.
Looking at the new cable the shaft end is round with a key stamped into it. What am I missing? How does this mate with what is on the pump? It appears there are two male ends, is there a coupling mating the two that I'm missing?
Thanks
Gunner 10
Thanks
Gunner 10
