Diesel Air Cleaner
showcrop
I need to get a gasket for my early diesel. The air cleaner is the type with the two thin straps that come from the back to the front of the cleaner. My question is, are the cup and thus the gasket for my cleaner the same as on the later type that has the one strap that runs side to side?
Hello Showcrop , If you have the Air Cleaner with the single strap that runs from front to rear or side to side that is the EARLY 1958 ONLY Air Cleaner , the LATER Air Cleaner is the one with two straps that run from the back to the front of the Air Cleaner and it was used from 1959 - 1962 . Both Air Cleaners take gasket part number 311802 and it is currently available from New Holland as I just a couple of them . Thanks Tony
(quoted from post at 08:09:38 08/01/14) Hello Showcrop , If you have the Air Cleaner with the single strap that runs from front to rear or side to side that is the EARLY 1958 ONLY Air Cleaner , the LATER Air Cleaner is the one with two straps that run from the back to the front of the Air Cleaner and it was used from 1959 - 1962 . Both Air Cleaners take gasket part number 311802 and it is currently available from New Holland as I just a couple of them . Thanks Tony
Thanks Tony
