jubileeguy
I purchased a 1954 Ford (Naa)jubilee tractor.
The old girl has had allot of use and I wanted to have a piece of equipment on my 5 acre second property to assist with some building and improvement. So far I spend more time and money trying to get her started than actual use.
My question involves the following: Has anyone installed an electronic ingnition upgrade in this type of tractor which is a 6 volt positive ground and if so what are your thoughts if any or any suggestions in the installation process.
I have researched some videos on you tube and saw something that I also need to know.
Is this tractor supposed to have a ballestor resistor installed between the ignition switch and the voltage regulator?
Thank you in advance for any and all assistance
