Real life, wifes health probs and work sched has pushed this poor row crop to the back burner.
got about 4 hours on her today, de-wired her, made up a new wire harness, got some lights and switch i salvaged off another units old tin.
steering wheel is a lil rough.. buffed on it. needs a few places filled.
started sanding the hood.
someone used paint stripper on part of the hood , left side, at one point. in fact. I thinkt he left side of the hood is from a different set of tin. it is straighter thant he right side, and has different paint on it.
Still forgot to refill the steering box, last time i worked on it I went thru the front pedistal.. and ran out of time to relube the worm box after adjusting thrust play.
Got the hyd diverter valve on it moving. it was locked up tight when i got it, had it soaking and just tapped on the spool today and it moved. a lil more tapping and then some tugging and it is now moving free.
Got the brakes adjusted and front hubs /bearings repacked.
just got to get that steering box lubed and then continue with the body work.
i probably need another good 10 hours of body prep before she would be ready for primer. Wonder how many weekends that 10 hours is gonna take.
