ford 3000 hyd leak
Anonymous-0
I had a hyd leak at the hyd pump and changed the "crush nut" last fall no problem for a while now started leaking around crush nut again when running the haybine and have to rake with the NAA. Not leaking when running the baler. Any ideals or any other fixes.
Thanks Joe C
pipe doesn't look nicked there maybe room to cut it off. Just got done cutting hay and when I raise up or lower the conditioner has a heck of a leak from the small line on the pump .I just put on the crush nut last fall and am wondering if I can cut off the pipe and work the crush nut back a little bit and reuse it?Luckily I rake with a NAA and when I pull the baler it doesn't leak. Someone told me to take the line off and drive a punch in the end to flare it out and put a small washer on it and tighten it up but you guys are the pros and that why I"m asking. Any and all suggestions will be appreciated
Thanks Joe
