Temp sensor 5610 II
Could someone tell me where the temperature sending unit is on a 5610 II? A quick look at my IT manual didn't show me anything. My temp gauge is not moving off cold. May need a new sending unit.
Temp sender is in the head next to the thermostat housing. With the key turned on, ground the wire at the sender and see if the gauge sweeps to full hot. If it doesn't you have a problem in the power supply, gauge or wires, not the sender. If the gauge sweeps full over... then you have a sender problem.
Rod
(quoted from post at 19:19:58 07/22/14) Temp sender is in the head next to the thermostat housing. With the key turned on, ground the wire at the sender and see if the gauge sweeps to full hot. If it doesn't you have a problem in the power supply, gauge or wires, not the sender. If the gauge sweeps full over... then you have a sender problem.
Rod
Yep that's where they are on a 4610 too
