jamesalred
New User
MY boss sent his Ford 2600 to a Vo-tech to have a new wire harness put on. They did something to the power steering and my friend had to replace #12 on the steering diagram. When my friend pick it up it was leaking around the brass fitting #18 and said he fixed it. When i started using it I notice it was out of power steering fluid so I filled it up it was leaking out of the plug again. I talk to a couple of mechanic and they said that it was probably the relief value stuck open and the easiest way to fix it was to just replace the power steering pump because the relief value is hard to rebuild. So I did. When I had finished replacing the pump I tried it out and it is still leaking out of the plug. So could my friend somehow have put #12 on wrong? I would prefer to find out before I take the steering completely apart.
http://i61.photobucket.com/albums/h56/Ultradog/3000%20and%203400/steeringcolumn.jpg
