1974 Ford 4000
Anonymous-0
Aloha All Got the PTO shaft out noticed the bearing snap ring 168104 pushed out. I purchased all new parts including a new cover C5NN733F which matches the old cover number 733F. Where does 81801870 snap ring go when there is no grove for the snap ring in the center housing or the cover. Evidently there is some pushing and shoving going on with the PTO shaft which is putting pressure on the snap rings 168104. Stumped Mahalo Mike
check to make sure your implement drive shaft telescopes smoothly and is not too long and in compression at any point when connected or lifting
