Ford 7700 Hydraulic Oil
Jlollman
New User
Using neighbors 7700 ford tractor as trade off. A
hydraulic hose went the other day, working fine.
Can't find where to fill or check fluid level. Use
to deer's all have dipsticks can't find one on the
ford. Any help
Should be a level plug on the left rear of the axle center housing slightly above and to the left of the PTO. Filler will probably be on the top right or somewhere in that vicinity on the rear.
Rod
Dipstick is on the left side of the rear axle center housing as Rod says, behind where your left heel is when you're sitting on the tractor. Part numbered 19B in this parts diagram (number 39 if it has a cab):
[u:91c2393d2a]Ford 7700 rear axle housing parts drawing[/u:91c2393d2a]
Fill hole is on top of hydraulic top cover near the rear of the tractor just to right of center, under you right butt cheek when you're sitting on the tractor. Plug for fill hole is part numbered 16 in this diagram:
[u:91c2393d2a]Ford 7700 hydraulic top coer parts diagram[/u:91c2393d2a]
