need help with 730 loader
kg4ajk
Found out a previous owner had welded the hub onto the hydraulic pump. Ground off the weld to find that the spines on the pump drive are shot. Is the pump shaft available as a replacement part?
If gear pump getting just shaft and gear is usually inpossible. The rest of pump is worn to. If vane the shaft may be avaible if have model number off pump. It is usually best to replace pumps when in that condition.
