Almost feels too easy and think I have to pull the position control lever further up to get lift when in implement control mode.
I changed the hydraulics fluid with the cheapest UTF I could find at Tractor Supply, label says it meets All specs. SuperS super trac 303.
I suspect this may be because I this UTF is probably thinner than what I replaced which was likely 80-90w fluid?
WJ
WJ
