4 cylinder 10's were only supplied with CCLS remotes. It should have one fitted to it as standard equipment. If t doesn't... you need to get one and the supply/return/load sense piping to hook into the priority valve pack under the seat. YOU CAN NOT REMOVE THE PRIORITY PACK on a 10 because it contains the system load sensing and feathering valves for the three point that are integral to it's operation... so just get the right valve and hook it up.
Rod
