640 air cleaner source
Royse
I'm looking for a used air cleaner for my 640. Part# EAE9600D
Same as the NAA/Jubilee I believe. 7 1/4 inch mounting holes.
Aftermarkets are available for ~$100, but I'd rather not spend
that much on one if I can find a good used one.
I checked OldFordTractors, ForestLakeTractor and Jim.UT's lists
and didn't see one. Anyone know where I can get a used one?
Thanks for checking Hobo.
If I don't find one I would be interested in making that one fit.
The battery tray is aftermarket anyway.
Jim.UT recently did a post on the difference between NAA and 600/800 battery trays on the NTC site. The only difference between the trays was the spacing between the attaching holes for the air cleaner. If you switch to an NAA air cleaner you will have to acquire a matching battery tray.
