Ford Jubilee
My ford jubilee clutch is stuck to the Fly wheel
Is there any way I can fix it without splitting it
I tried spraying kerosene in thru the starter hole with no results
ANY HELP?
Walt
Run it as slow as it will go and pop it Into gear. Then drive it and stomp on that brake and clutch at the same time. Might have to try it a few times. Had very good luck wit that technique.
...and once you get it unstuck, to prevent this from happening again, whenever you park it block down the clutch pedal by sticking a short 1x2 piece of wood above the pedal arm. Jubilees are notorious for getting stuck clutches overnight.
block clutch, put in high gear, lock brakes, use a screwdriver to set there and just keep bumping the starter over 1 bump at a time.... many tiems that will pop them loose
