Carlis Baker
New User
I have purchased a 1957 Model 801. Gas burner that runs excellent. It needed a new left front tire. It came with a 1 year old bush hog attachment. My question is this.
I can purchase a old Model 800 (Former State or County tractor with front end loader, backhoe, power steering etc. All hoses are bad, and it looks terrible. Can I refurb the pieces to working order, economically and use them on my tractor.
yes, ps components from an 00 fit an 01
yes.. the loader that fits an 00 ag model will fit an 01
the backhoe should swap over.. but perhaps sice you have 2 tractors.. leave the hoe on the one.. unless 1 front pump feeds the hoe and loader.
also make sure it really is an 800 and not an industrial. lastly.. does the unit with a hoe have a 4pt or a blank top cover. have to keep that all in mind..
How can I identify the differences. If you email me direct. [email protected]. I will send some pictures. The yellow tractor is in poor running condition and looks terrible. Not an issue with a work tractor, but just preference.
The main items I would like are the loader, and power steering. I know changing out a backhoe is a pain, and if possible leaving it on one tractor is a better option.
The easiest way to tell an ag chassis from an industrial is that the ag chassis models had 3 piece adjustable width front axles, and the industrial models had a single piece non-adjustable front axle, which was stronger for loader work.
Also, the fact that the one with the loader and backhoe looks terrible doesn't tell you about how it works. You might find that it's in better shape mechanically and just needs to be cleaned up and painted.
hyd top cover vs blank plate is ez to ISD>
also EZ to see where hyds feed the loader and how.
if it is a hd industrial.. make sure it is not cable power steering.
