alg
Guys,
Anyone have a Napa part # fro a temp gauge for the early 1000 series Fords.172 engine.
It's nothing special- just a standard off-the-shelf mechanical water temperature gauge. The capillary tube will be way too long so you just roll it up under the dash.
Part Number: BK S61525
Product Line: Balkamp
Attributes:
Bezel Color : Black
Gauge Dial Sweep Degree : Orange-Green-Red
Gauge Face Color : Black
Illuminated or Non-Illuminated : Illuminated
Manufacturer : Sparex
Manufacturer Part Number : S.61525
Mechanical or Electrical : Mechanical
Mounting Hole Diameter : 2"
Outer Finish : Black
Package Contents : (1) Gauge
Bought a universal gauge at TSC,the sensor that goes into the block was to large.
Do you know that you don't use any bushings on the Ford? You insert the sensing bulb into the head and tighten the nut that the capillary tube passes through.
