SouthCarolina8n
New User
I"m having trouble with my "52 8n hydraulics. With my mower attached, the lift won"t pick up. Without any weight it would go up and down great but dropped immediately after turning pto off. I drained the fluid and replaced with new GL-1 90 weight. I also replaced the pressure relief valve while I had it drained. The old fluid was fairly watery. Now the lift goes up and down great without weight and holds when pot is turned off. If I stand behind it, I can usually hold the arms down with the lift in the up position. Occasionally it acts as if the lift is working and pushes up over my efforts to hold down.
I am guessing that when I hook my cutter up, it will not lift the weight.
What should my next swing at this be? Replace the piston with NAA o ring style or something else. Thanks for the help.
