Getting ready to start working on the 4000 WF RC now that the kids are off to college and we're empty nesters. Do you guys just use jackstands under all four axle areas when removing the tires? Want to give the entire thing a good cleaning before priming and paint. Needs valve cover and oil pan gaskets, new fluids, etc.... Everything else is mechanically sound on it but now just want to pretty it up some. Any other suggestions for blocking it up for the work? Paint I was going to order is Valspar Tractor and Implement High Gloss Enamel 4431-12 Ford Blue and 4431-13 Ford Gray. Anyone know if these are correct for a '62 4000 4 cylinder? Thanks!
