Help identify wheels
I was a a neighbor's tag sale today and came home with a set of mounted rear tractor tires. I thought they might fit my Ford, but the bolt circle is way too large. The size is 14.9-24. The bolt circle is 8-lug 8" and the center hole is 6". ANy idea what they might fit?
Thanks
Where are you located?
I might be interested in them.
Some of the 3000s with spinout wheels used an 8 on 8" center with an adapter plate to make them 8 on 6"
I have a set here.
If the opening is 5-1/2 inches it would go on the Ford SU size thousand series. If it's actually 6 inches it would bolt right on a Kubota M series.
The 24 inch size I think would be small for the 4000 but would fit right on my 4100 which has the low front axle and uses 24 inch rims (with a 5-1/2 inch hole) for the turf tires on there now.
I'm in Missouri and will travel for them if the price is right and UltraDog doesn't claim them first as he spoke first.
Email should be open below on tab.
Well, Tom & Ultradog, I'm in Massachusetts. I suspect that's a bit far for you. However, New England is lovely this time of year. If you have any interest, my e-mail is open, drop me a line.
