1976 3 lunger 8 speed. Are the draft and position control shafts two separate pieces? One inside the other? Looks to be so in the books, but on mine if you move one they both move.
Anyone within an hour or so of Clare/Harrison Mi willing to babysit me while I try to fix it? I'll drive to you or pay gas. I do have the gasket/seal set for the lift cover.the lift goes up and is strong but you have to hold lever or it springs back to center and it drops. Also position lever only has about 1.5 inch of travel. Just doesn't feel right. Not that I would know for sure. New to me last year and it sat for 6 yrs.
Another ?. Do you have to split tractor to put new seals on brake rod that goes through the rear differential?
