FORD 3000 STARTER P/N
Anonymous-0
I am trying to find the part number for the starter on my 1974 Ford 3000(Gas / Mod #: C1023C). The only markings I can find on the present starter is C5NF-11131-B2. The stater measures 4 1/2" in diameter. I found one result searching C5NF-11131-B2, and that was flea bay,and the starter shown was not a good representation of what I now have.I have searched the internet, looked in three different catalogs,checked my FO-31, but cannot be positive of which stater I need. Are you able to help me identify the appropriate part number? Thanks....
Casting number on a part is not necessarily (and usually more times is not than is) the part number.
The original part number for a 3 cylinder 2000/3000/4000 starter is D7NN11001A. A remanufactured one would be D7NN11001AR. Those would be the numbers you would use a a New Holland dealer parts counter. Searching Google on that part number will return lots of aftermarket starters that will work as well and will probably be quite a bit less money than he one you would get at a new Holland dealer.
