hydraulic seal blowing out
LarryWA
My Ford 7000 has started blowing a hydraulic oring seal where the banjo bolt connects the remote connector onto the cover (hydraulic control box) under the seat. I never had a problem until the last couple of weeks and now it has happened 3 times while using a pull behind swather.
My guess is it is building too much pressure when I lift or lower the swather. What is the most likely problem?
Seal #18 should be a square cut o-ring, meaning it has flat sides. Go to your local NH dealer and order the correct seal. This should solve your problem.
Sorry I did not reply to your last post. I don't often venture onto page 2.
Thanks for your replies. After looking at the description of the seal on New Holland's website, I believe you are correct about having the wrong seal installed. I have ordered the correct seals from New Holland and will give it a try.
