Ford 4600 power steering leak
Anonymous-0
Tractor has the cylinder in the steering column . I had to put a new power steering pump on it and now the cylinder is leaking mainly I think on the right side of the column there is a small line coming down from the top. Looks like its leaking at the bottom. can anyone give me advice on what that line does and how to fix it. thanks
If you are referring to tube #28, then seal #30 is what you need, 4 of them, 2 top, and 2 bottom.
