chrisinsoky
3000 gas will start but not run for more the a few secs, classic carb float issue, gonna pull carb when i get home,
but for now fuel coming from weep hole at the bottom
now for the silly questions
#1 cyl. is closest to the fuel tank right?
if the tractor is 12 volt ground to ground the neg side of the coil goes to the distribitor right? plus side to the ignition switch.
