chrisinsoky
i ve got a few ?s
i have the numbered key switch 1 2 and 3.
will the key switch handle the batt. at 12 volts straight, im not running a volt reg. so the factory wiring diagram is getting sketchy. second if i wire 3 to the solonoid i should have key starting correct? (at one time the po had a push button instead of a starter solonoid)
#2 on the ign. switch should go to the volt stabilizer on the dash. correct?
