Lanexa Speedway
Quick question about hydraulic pump housings. For a x00 or x01 series machine with the piston pump, is it common for the part of the pump housing that has the two bolts that attach it to the engine block to crack? Part number on this is NCA-905. I have a good working pump, but when I went to clean it up to paint it, I noticed that two of the four ears that bolt it to the main pump housing are cracked. The "mechanic" before me must have seen it and siliconed it up. Not leaking, but obviously, it's not going to cut it for me on my restoration.
Just curious if this was a common ailment or not.
And if any of y'all have one lying around, I may be interested in buying. The rest of the pump can be junk, I don't care, just need that end housing.
Thanks,
Kevin
Thanks,
Kevin
