loss of 5th gear
Rancher Rick
New User
I was driving my 650 ford about 5 miles home in 5th gear everything was going great then halfway home I get a rattle in the trany no 5th stop the tractor start in 4th shift to 5rh works for a while rattle no 5th what do you think is happening I should mention new clutch with trow out
Remove the top cover and inspect the shift forks for loose set screws, wear and damage.
Dean
ps. if you want 5th you start in 5th. this isn't a full synchro tranny that you run the gears on like your 4-5 spd truck in the parking lot...
