This was in a non runner I picked up. ORC trans.
It's an 881. I bypassed the electric system to run
the engine off the battery and jumper to the coil.
None of the oil pressure light or other safety
switches for the trans are hooked up, don't know
if that matters?
I cleaned the screen and replaced the fluid. The
pto cable is broken in the ON position and does
spin (with force)when tractor is running.
I tested with a gauge and get zero pressure at all
three servos running thru all gears.
I'm thinking may be a defective pump. Anything
else you guys can recommend before tearing this
all apart?
Thanks, Kirk
if that matters?
all apart?
Thanks, Kirk
