Greg Wolodkin
Looking for advice on the rebuild of the lift on the '66 3400. It had sat for a while, and looks like condensation had caused some amount of rust to form on the underside of the lift cover. Not enough to seriously damage the parts that are rusted, but it did cause some rust flakes to be floating around in the fluid.
I've cleaned off all of the loose scale, but I'm tempted to break things down a little farther and get things shiny again with a wire wheel, maybe hit the larger cast parts with the needle scaler, then prime and paint before re-assembly.
Is there anything special about the paint used on the inside of the lift and tranny?
Thanks for any advice -
Greg
Greg
