Ford 2000 SuperID problem
dayboats
New User
I have this great tractor but have to replace the flywheel gear ring - great. Problem is I only have a partial number from the flange and need to get the right parts.
??? B15B
D20007B2G
A?48-734
Metal strap holding the cab gets in the way of missing numbers. If someone can help identify this tractor for me it would be appreciated and save me removing the cab to get the number.
Other than the flywheel teeth ring are there any gasket sets I need to do the job and should I replace the clutch plate at the same time? Help appreciated.
You should always specify whether you have a 4 cylinder 2000 or a 3 cylinder 2000, and whether it's gas or diesel.
Part numbers for 2000 flywheel ring gears:
4 cylinder gasoline & diesel: 9N6384
3 cylinder gasoline: C5NE6384B
3 cylinder diesel: 83949153
The "Super" part has me thinking he may have a Super Dexta,
which is also sometimes called a 2000, and is a 3-cylinder.
(quoted from post at 14:23:00 06/16/14) The "Super" part has me thinking he may have a Super Dexta,
Interesting. I was told it is a Ford 2000 Super Dexta and it is decaled Ford 2000 Super. Paperwork, being France, is sketchy to say the least. I thought all Super were 3000 machines. If I can get it going with a new ring gear it runs great and we have used it to launch boats for the past 3 years. It runs just fine and only nedds a set of steering bushes since it wobbles a bit at speed.
Quick Picture of the animal
[/url]
That is a '65-'68 2000 or 3000. As far as the ring
gear, it doesn't matter which it is...the 2/3/4/5000
diesels all used the same ring gear.
Super Dexta is a completely different animal and the part number for the flywheel ring gar is different than the numbers I posted before.
The correct part number for Super Dexta would be 957E6384B.
Oops, posted this before I saw your picture. That is definitely a '65-'68 2000 or 3000 as FordFarmer said.
So which part number is the one for me? Sorry for being so stupid.
or Super Dexta 957E6384B
It should use the one for the 3 cylinder thousand series diesel: 83949153.
Nothing personal here, it's just that I have a strange sense of humor, and every time I look at that picture, Jeff Foxworthy's voice pops into my head... so I had to post it... " You know you might be a redneck if... you drive your tractor to the C*asino (or the supermarket)".
Edit: Wierd that this site won't let me post that word without the asterisk in it, it claims that the word C*asino without the asterisk is forbidden here. Oh well.
By the way, is that a combination C*asino and supermarket, or is C*asino just the name of the supermarket chain?
Funny. The only reason for the tractor at C*asino was that we had big floods here so the car was stuck at the house as the garden flooded to 2ft high. The tractor was the only way to get about even if the trailer behind was floating!!!
I have found some more numbers on a plate in front of the radiator.
Type 2000 : Engine L7488647A30A : Series A148734 : 2340Kg
Thanks for the advice
