New to the forum and old Ford Tractors.
I have what I suspect is a 1962 Ford 4000, but not sure. Original color was blue. Been repainted orange. Sheet metal all messed up/bondo/repaired (think it was crashed).
It is a 4 cyl. diesel, 4 Spd. Model ID numbers are etched away, but here is what I found:
4*1-D (* might be a 6 or 0)
312480 - Differential
310835 - Tranny under right side pedals
CONN6015J - (found this in prior posts.
Also, found this washer sitting on the inspection cover off the underside of the bellhousing/tranny ? Reverse idler or PTO thrust washer ? WHERE DOES IT GO ?
Thanks,
Sam
Thanks,
Sam
