71 3cyl diesel.
its not coming from the rear end hydraulics because I drained them both today and hydro fluid is perfect.
Is the only way for water somewhere thru the top cover?
2 months ago. I replaced orings on shifters under the top cover, ran soundguys solution thru it, installed sound guys racquetballs on the shifter shafts and today the fluid is milky once again.
If the only way for water is thru the cover I suspect either where the neutral safety with goes thru the cover or a suspect low spot spot weld where someone spot welded one of the shifter brackets. I used silicone on both of the above 2 months ago but today I noticed the aftermarket spot weld is holding water.
My guess is I need to redo my silicone seal on the low spot weld and the neutral safety wire entry?
