While working on the steering gearbox on my 850, I've got the hood, dash, air cleaner, battery holder, and wiring taken off the tractor. I'm not looking to do a restoration or paint job at this time, but is there anything I should be taking care of while I've got this much taken off the tractor?
Since acquiring the 850 this spring I've changed the transmission, hydraulic and rear diff oil. I'm replacing the wiring harness and tach or tach cable (I have both, but it appears to only need the cable so I might save the zeros on the new tach for a more appropriate time) and checking oil pressure and temp gauges while I'm in here. Anything else?
Brian
Brian
