Hi
I recently bought this old 515 from a friend that used it for ten or so years on his small dairy and sheep farm. Before that it was owned from new by a local town road department. It has mostly been sitting for the last two years. I think it is a 1978 and it has about 3000 hours.
I am hoping to find someone with experience with the steering set up on this tractor.
The problem is that the power steering will not kick in unless the steering wheel is jerked hard when starting to turn the wheels.
So if I turn the steering wheel normally there is no power steering but if I give the steering wheel a good hard jerk when I start to make a turn I can feel the power steering activate and if I continue to turn the wheel with out stopping it will stay on while the steering wheel is moving, as soon as I stop turning the steering wheel I have to give a hard jerk to get the power to come on again.
Has anyone come across the problem before? I have the grill and radiator out and am starting to clean out the area around the actuator and linkage.
Thanks
Ford 515
Tractor # C571210
Model # DV214C
Unit # 8D11B
Engine # 8B02B
Trans # 8A10C
Rear Axle # 8A30C
Hydro Pump # 8A28A
Hydro Lift # 7M19B
Thanks
Ford 515
Tractor # C571210
Model # DV214C
Unit # 8D11B
Engine # 8B02B
Trans # 8A10C
Rear Axle # 8A30C
Hydro Pump # 8A28A
Hydro Lift # 7M19B
