My grandson bought a 601 diesel with a front
loader on it. The lift has not worked in years. I
have pulled the top off twice and replaced the
unloading valve O ring with the one that comes
with these Chinese gasket and O ring sets. Cleaned
up the unloading shuttle and the bore good and
bright with 400 grit paper and washed and blew
everything down. Still no lift. I even pulled the
pump and checked everything out. Nothing wrong
with it. Primes good and seems to have good
pressure and flow.
Since I first posted I have taken the hack
pressure/check valve/s out and inspected. OK.
Pulled the lift cylinder and control housing and
even pressed out the two bushings, control valve
and unloading valve bushings. Probed all the
drilled passage ways to the bottom of the holes.
probed the auxillary adapter plate passages and
all are open to their next openings.
With air pressure to the pressure port on the
cover at right front corner I can cause the
unloading valve to open and close with the control
valve is moved in and out but when the unloading
valve goes to the raise position it seems to just
block the air and it does not go to the ram
cylinder piston.
Still no lift
Any ideas would be appeciated.
Thanks, Zane
pressure and flow.
cylinder piston.
Still no lift
Thanks, Zane
