TractorLinks.com
Order Ford 2000 Parts Online
Re: Back end and transmission fluid - Ford 2000 3-cyl gas 4-
Sean in PA
05-23-2014 10:14:16
That dealer apparently does not know what he's talking about with regard to that model of tractor. Yes, mot of the 4 cylinder and larger engine tractors post 1972 or so had a common sump, but not the 1965-1975 3 cylinder tractors.
There is no dipstick for the rear axle/hydraulics sump in a 3000, but it is a separate sump. The level check for the rear axle/hydraulics sump is a hole on the right side of the center housing with a square headed pipe plug in it, near where your right heel is when you're sitting on the tractor. You open up the level check plug and fill it through the the fill hole on top of the differential housing until it just starts to drip out of the level check hole. Buy yourself an Operator's manual and a Service manual and see for yourself.
