Samhottinger
New User
I have a Ford Model 600 that has been converted to 12 volt before I bought it. I started to work on it last year and got side tracked. I rebuilt the ignition including the coil at that time. The tracto ran, but needed a carburator rebuild and I didn't get around to it until this week. Basically the tractor sat for a year. I got the carburator rebuilt this week, but the tractor has no spark. I replaced the points, condensor, plugs and plug wires. It still wouldn't start, so I tested to see if I had current to the coil, and I do. However, I have nothing coming out. I suspect the coil is bad. When I bought the coil, the guy told me I didn't need the resistor block, but I am not so sure at this point. I suspect that I may have installed the wrong coil for a 12 volt system, or that I needed the resistor block. Can anyone tell me what coil to use with a 12 volt system? I saw a post that mentioned this coil NAPA IC14SB. Do I need a resistor block to use this?
Thanks,
Sam Hottinger
Thanks,
Sam Hottinger
