Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 841 Parts Online
Re: Ford 841-d or new lawn ornament???
stufferdarwin
05-21-2014 15:29:38
Marty 52;
Spindles are fine, they move freely unhooked and are well lubed. Also cylinders activate correctly, but I don't know how much pressure they are generating. Obviously not enough.
Errin OH;
I looked up that cardone pump you mentioned and it sure looks right to me & they are readily available at $125 to $150. All the tractor places have them priced from $500 to $700 , go figure!
If it's the right pump at $125 I'll replace it just on general principle.
Sean in PA; Thanks for the current spec #. Got any idea what off the shelf readily available product I should get for a test run on this pump? I'm really thinking this dexron VI is not the ticket
Jeff PK ;
Where is this control valve you mentioned? In the pump or in the steering box? I don't have the shop manuals yet. Boy do I hope it's in the pump.
By the way I do have good fluid return to the pump reservoir
Thanks guys..I'll keep at it a while longer
Darwin
jeff pk
05-21-2014 18:56:24
 Re: Ford 841-d or new lawn ornament??? in reply to stufferdarwin, 05-21-2014 15:29:38
control valve is attached to the steering box. The tubes from the cylinders and the pump all run to it---down under the dash. If it starts leaking hydro fluid low, or high at the wheel, along the steering column you have a busted seal...
stufferdarwin
05-22-2014 08:49:36
 Re: Ford 841-d or new lawn ornament??? in reply to jeff pk, 05-21-2014 18:56:24
Jeff;
I was afraid you were going to say that. I peeked under there and there is no sign of leakage. The shop manuals are on the way now, so I'll have a look at the degree of difficulty and maybe I can find a rebuild kit for that valve and have a go at it.
So far I'm only the price of a battery and manual into this thing.
4 tires will be a bit pricey. Electrical won't be bad, so if I can catch a break on this power steering I should have a real good machine for less than $2500. When I got it I thought it was only 20 or so years old..it looks great. Given the fact that it is 55+ years old I think I'll give it a little more TLC.
Thanks for your help
Darwin
