TractorLinks.com
Order Ford 2000 Parts Online
Re: Back end and transmission fluid - Ford 2000 3-cyl gas 4-
Sean in PA
05-21-2014 10:20:52
The fill hole next to the shifter is for the transmission and the one on the rear axle center housing is for the rear axle and 3 point hydraulics. They should be 2 separate sumps. There are seals on the transmission output shaft and the PTO shaft that go between the two sumps, and those sometimes leak and so they in effect become a "shared" sump, but there's not supposed to be a 1/2" hole in the wall between them. Where exactly is this hole between the two sumps (How far down from the top cover of the rear axle, and how far in from the left or right side?). There are some holes in that area, but they should have the shifter rails in them and shouldn't just be open.
