146robinson
Thanking I should probably replace the front pins and wheel berings on 1957 800 I have tried to figure out what 800 it is best I can tell it is an 835 not sure the manual says the numbers will be on the left front side of trans housing but all I see is numbers on the right side trans housing in middle by the brake pedal 310835 under that there is z36 could be confused on that but anyway the front end has been worn out for years don't have a shop manual but thanking of getting one anybody know if the one at tsc is a good one and if anybody has done this before looking for a heads up on what kind of problems to expect to have thanks
