TractorLinks.com
Order Ford 800 Parts Online
front pins and wheel berings on 800 series help
146robinson
05-21-2014 07:34:47
Thanking I should probably replace the front pins and wheel berings on 1957 800 I have tried to figure out what 800 it is best I can tell it is an 835 not sure the manual says the numbers will be on the left front side of trans housing but all I see is numbers on the right side trans housing in middle by the brake pedal 310835 under that there is z36 could be confused on that but anyway the front end has been worn out for years don't have a shop manual but thanking of getting one anybody know if the one at tsc is a good one and if anybody has done this before looking for a heads up on what kind of problems to expect to have thanks
146robinson
05-21-2014 18:56:13
 Re: front pins and wheel berings on 800 series help in reply to mhb@ufe, 05-21-2014 07:34:47
you can never have to many manuals on hand
Sean in PA
05-21-2014 18:02:24
 Re: front pins and wheel berings on 800 series help in reply to 146robinson, 05-21-2014 07:34:47
The I&T Aftermarket Service Manuals that TSC sells are adequate for most things but there's some things that you would want the original Ford service manual for. Then there are things that the Ford manual will tell you how to do if you have special tools that are not readily available, but the I&T Manual gives you "alternate" procedures to do those things without the special tools, like adjust the 3 point lift control linkage. So most folks keep both on hand.
You can buy the I&T and the Ford Service Manual right here on this web site, as well as the Operator's Manual:
Ford Service manual
Operator's manual
146robinson
05-21-2014 16:11:50
 Re: front pins and wheel berings on 800 series help in reply to soundguy, 05-21-2014 07:34:47
and what about thous books at tsc is there better ones out there
Sean in PA
05-21-2014 14:02:25
Engine tune-up specs for the 172 ci gasoline engine is the same for all 1955-1964 tractors, so what's in your 800 series manual should be fine. Additional info in the 601/801 series manuals would be for the diesel engines and the Select-O-Speed transmissions, but all of the information for the gasoline engine and 4 speed transmission should be pretty much identical between the manuals.
146robinson
05-21-2014 14:11:25
 Re: front pins and wheel berings on 800 series help in reply to Sean in PA, 05-21-2014 14:02:25
again thanks I appreciate the info
Sean in PA
05-21-2014 13:24:22
Then 841 is the model number, which means that is an 801 series tractor, not an 800 series. The 801's were just a little later than the hundred series and had a few minor improvements. An 841 would have had the 172 ci engine, 4 speed transmission, non-live (trans driven) PTO and 3 point lift when it left the factory.
70636 would be the serial number, which would make it a 1959 841 tractor.
I believe the front axle for the 801 series is still pretty much the same as the 800 series. Here's a link to the parts page for the 841 front axle and steering:
Front Axle & Steering
And here's the parts drawing for the front wheel and hub assembly including the bearings:
Front wheel and hub
u[date: fixed the first link above.
This post was edited by Sean in PA at 13:59:28 05/21/14.
146robinson
05-21-2014 13:48:04
 Re: front pins and wheel berings on 800 series help in reply to Sean in PA, 05-21-2014 13:24:22
I appreciate that Sean in pa I have had this tractor for years and have always been told that it was a 800
146robinson
05-21-2014 13:57:07
 Re: front pins and wheel berings on 800 series help in reply to 146robinson, 05-21-2014 13:48:04
I wander if there is a owners manual out there that I can download I have one for the 600/800 series I found (I have a 600series two) but since I have always thought it was a 800 I have gotten points set timing and valves for a 800 series two
soundguy
05-21-2014 10:29:45
you should NOT be looking for raised casting numbers. you should be looking for weak hand stamped numbers into the flat of the bellhousing aft of the starter.
that said. if it is an 800 series. gront end parts are the same.
146robinson
05-21-2014 11:12:22
 Re: front pins and wheel berings on 800 series help in reply to soundguy, 05-21-2014 10:29:45
I see 841 and 7063 6
soundguy
05-21-2014 15:46:33
 Re: front pins and wheel berings on 800 series help in reply to 146robinson, 05-21-2014 11:12:22
Congrats on a 59 841
you ask if we here have ever done front end work on our 50-70 year old tractors.... (chuckle)
146robinson
05-21-2014 16:08:30
 Re: front pins and wheel berings on 800 series help in reply to soundguy, 05-21-2014 15:46:33
yeah I thought you'd find that funny chuckle (these machines were made to hold up)
146robinson
05-21-2014 12:08:58
Quoting Removed, click Modern View to seethe numbers are on the flat spot just after the starter that's all I see and the numbers are pretty easy to see they are recessed.have any of you done this before is it hard to do any special pullers or anything needed
Sean in PA
05-21-2014 10:11:49
If it is an 800 series, then the specific model number would be 820, 830, 840, 850 or 860. There was no such thing as a 835 in the 800 series.
Stand on the left side of the tractor and put your right hand on the clutch pedal and your left hand on the starter. The battery should be right in front of your face. Look down below the battery and you should see a flat spot on the transmission housing that faces up. The model and serial number should be stamped into that flat spot. They will not be raised up casting numbers like the 310835 that you found on the right side.
Front axle parts should be the same for all 800 series tractor, regardless of the specific model. The variations between the models had to do with which transmission, PTO and 3 point lift options it had, but they all had the same front axle assemblies.
