TractorLinks.com
Show Parts for Model:
Re: One wire Delco charging issues
John in La
05-21-2014 07:24:50
Before we type a book of all the things it might be hack out all the old wiring and wire the alternator the way it was made to work using a 3 wire setup.
RedDawg
05-21-2014 07:53:43
 Re: One wire Delco charging issues in reply to John in La, 05-21-2014 07:24:50
That's the diagram I used on my 640. Pulled out the rat's nest, rewired using solder and heat shrink wrapping around the connectors and it works great. No more guessing if it's going to work. Didn't take long either.
John in La
05-21-2014 08:08:40
 Re: One wire Delco charging issues in reply to RedDawg, 05-21-2014 07:53:43
Thanks for the feed back and flowers RedDawg.
I see the drawings all over the web and many do not even know that I drew them to help people just like you.
radara4077
05-21-2014 08:39:02
 Re: One wire Delco charging issues in reply to John in La, 05-21-2014 08:08:40
Glad you're still posting, John. I used your comprehensive post in the archives to re-wire my 841 a couple of months ago. Runs great! Very helpful! I went front knowing next to nothing about how to wire a tractor to being able to do it all on my own thanks to you!
Wired the "automobile type" starter switch (start and on switches on the same key). Very pleased with it!
cbrown9064
05-21-2014 09:47:52
 Re: One wire Delco charging issues in reply to radara4077, 05-21-2014 08:39:02
The only problem with wiring it like that is you eliminate the neutral safety switch...I would rather keep the safety switch, but that is just me.
John in La
05-21-2014 13:28:38
 Re: One wire Delco charging issues in reply to cbrown9064, 05-21-2014 09:47:52
radara4077 used a different wiring diagram that I have out there.
The diagram I have pictured here still uses the neutral safety switch.
HCooke
05-21-2014 12:23:13
"The only problem with wiring it like that is you eliminate the neutral safety switch"
Look again - it is still there.
cbrown9064
05-21-2014 20:30:26
 Re: One wire Delco charging issues in reply to HCooke, 05-21-2014 12:23:13
Read again...he bypassed it with a key switch.
