Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Back end and transmission fluid - Ford 2000 3-cyl gas 4-spd
FiddlinFarmer
05-20-2014 20:01:52
206.225.72.198
A couple weeks back, I was asking about re-attaching the PTO engage lever that had stopped working. I finally had a chance to work on it tonight. The sleeve that the lever-rod attaches to had just rotated down where the lever-rod no longer touched it. It was easy to rotate it back into place and re-tighten the screws that held it in place.
What I found when I got in there was that the fluid was a light brown color - kind of like well-creamed coffee. Sean_In_PA answered my question very well about what the fluid should be used there as he replied to me a couple weeks ago, though I have no idea what that kind of fluid should look like.
When I got the nearly 8 gallons drained, I took this picture to see if it would show you enough to tell if it looked off to you guys. A friend of mine suggested that it looked like water had gotten into it. In the photo, you can see that something is trying to separate out from the fluid.
After draining the fluid I also noticed that it appears that there is a small machined hole (maybe 1/4" diameter) between the back-end chamber and the transmission chamber. Is the fluid supposed to be shared, or is there something missing that would seal the two chambers off from eachother? By peeking into the fill hole for the transmission it did look like the same milky stuff, though it was hard to see very clearly past the mechanical parts.
Thank you,
FiddlinFarmer
[Reply]   [No Email]
Sean in PA
05-23-2014 10:14:16
98.114.179.25
 Re: Back end and transmission fluid - Ford 2000 3-cyl gas 4- in reply to FiddlinFarmer, 05-20-2014 20:01:52
That dealer apparently does not know what he's talking about with regard to that model of tractor. Yes, mot of the 4 cylinder and larger engine tractors post 1972 or so had a common sump, but not the 1965-1975 3 cylinder tractors.
There is no dipstick for the rear axle/hydraulics sump in a 3000, but it is a separate sump. The level check for the rear axle/hydraulics sump is a hole on the right side of the center housing with a square headed pipe plug in it, near where your right heel is when you're sitting on the tractor. You open up the level check plug and fill it through the the fill hole on top of the differential housing until it just starts to drip out of the level check hole. Buy yourself an Operator's manual and a Service manual and see for yourself.
[Reply]  [No Email]
FiddlinFarmer
05-23-2014 07:36:23
206.225.72.198
I talked with my local Ford/New Holland dealer yesterday. He said that the transmission and rear hydraulics commonly have shared sumps. If the transmission has an independent sump, the fill cap will have a dipstick on it. Mine does not.
I got everything back together, re-sealed, and flushed with diesel. After filling the back end with about 5.5 gallons of JC20 (only thing I could find locally that physically listed any 134 spec) and the transmission with another 1.5, both chambers were full to the check valves. I'll have to check the check valves again when I find some truly level ground, but everything is working well now.
Thanks for all of the input!
FiddlinFarmer
[Reply]  [No Email]
FiddlinFarmer
05-21-2014 14:15:37
206.225.72.198
It looks like it might be near the reverse gear shift rail (part 27), but if that was missing, I am sure I would have noticed the reverse gear not working... unless I have an unwanted surprise waiting when I finish up and try backing away from the barn ;)
The diagram shows some kind of notch or hole just below that part. That could be the location I was looking at. Any idea what that notch or hole is?
[Reply]  [No Email]
Sean in PA
05-21-2014 13:15:11
98.114.179.25
The manual transmissions can take gear oil or the M2C134D UTF. Most folks use the 134D UTF in both sumps because of the possibility of the seals leaking between them.
Here's a link to the parts diagram for the transmission case for that 4 speed transmission. You can see the back wall of the trans that meets up with the rear end sump. is it one of the holes that the shift rails go through in the picture, or is it something else?
4 speed transmission case
[Reply]  [No Email]
FiddlinFarmer
05-21-2014 11:53:00
206.225.72.198
The hole was closer to 1/4" diameter. Going by a vague memory (and wishing I had taken pictures) it was something like 2" from the left side (left when as if driving the tractor) and maybe around 4" down. It might have been close to the same height as the rear-end fill check screw. Maybe I could do better with percentage distance... about 25% from the left and about 50% down.
If the transmission is supposed to be separate, does it use the M2C134D spec fluid?
This post was edited by FiddlinFarmer at 11:55:23 05/21/14.
[Reply]  [No Email]
Sean in PA
05-21-2014 10:20:52
98.114.179.25
The fill hole next to the shifter is for the transmission and the one on the rear axle center housing is for the rear axle and 3 point hydraulics. They should be 2 separate sumps. There are seals on the transmission output shaft and the PTO shaft that go between the two sumps, and those sometimes leak and so they in effect become a "shared" sump, but there's not supposed to be a 1/2" hole in the wall between them. Where exactly is this hole between the two sumps (How far down from the top cover of the rear axle, and how far in from the left or right side?). There are some holes in that area, but they should have the shifter rails in them and shouldn't just be open.
[Reply]  [No Email]
soundguy
05-21-2014 05:55:08
184.240.222.178
 Re: Back end and transmission fluid - Ford 2000 3-cyl gas 4-spd in reply to FiddlinFarmer, 05-20-2014 20:01:52
rear end and hyds share oil.. trans is a seperate sump.
UTF fluid for both of them.
yer oil looks wet/emulsified.
I'd flush with some diesel/atf-f /alcohol before refilling.. otherwise the new oil will look cloudy like the old oil in 5 minutes..
[Reply]  [No Email]
FiddlinFarmer
05-21-2014 08:39:34
206.225.72.198
 Re: Back end and transmission fluid - Ford 2000 3-cyl gas 4- in reply to soundguy, 05-21-2014 05:55:08
So if you are saying that the transmission has a separate sump, I need to make sure I am looking at the correct parts. Please see the image and let me know if I have things right or not.
It is the transmission that is under the plate that the shift stick is mounted to, right? The 1/4" hole I mentioned goes between that section and the rear section where the PTO engage and the 3-pt lift mechanics are located. Or is the actual "transmission sump" located elsewhere? (I have very little experience in this arena and I can't say 'thank you' enough for everyone's willingness to help me understand)
Since the rubber boot at the base of the shift lever is very weathered, I suspect it is the most likely source of the water contamination. I have already ordered a new boot from the YT store. Are there any other likely suspects I should check?
Thanks,
FiddlinFarmer
[Reply]  [No Email]
soundguy
05-21-2014 10:25:36
108.112.136.53
 Re: Back end and transmission fluid - Ford 2000 3-cyl gas 4- in reply to FiddlinFarmer, 05-21-2014 08:39:34
ditto what sean said.
seperate sumps.
where did you see the hole?
[Reply]  [No Email]
Shetland Sheepdog
05-21-2014 06:05:16
71.168.76.63
Well dang Sounder! Ya fergot to include the magic 134 number! :shock: :wink:
[Reply]  [No Email]
soundguy
05-21-2014 06:15:52
184.240.222.178
 Re: Back end and transmission fluid - Ford 2000 3-cyl gas 4- in reply to Shetland Sheepdog, 05-21-2014 06:05:16
I think you'd have to look long and hard these days to find a UTF that was not suitable for these old fords...
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
