Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 660 Parts Online
Re: 660 hydraulics
Billybuck
04-28-2014 18:56:59
Jesse, you may recall I just replaced the cylinder safety valve last Fall. Should the safety valve even open if there is not a problem causing excessive pressure? The source looks to be from the same spot as last fall though it was shooting out probably because I had a bush hog attached when trying to lift.
JMOR
04-28-2014 19:01:14
 Re: 660 hydraulics in reply to Billybuck, 04-28-2014 18:56:59
Quoting Removed, click Modern View to seeNo it should not open. It is only one of 3 sources that potentially dump back through the same un-gasketed path.
Copyright © 1997-2015 Yesterday's Tractor Co.
